Labview 8 to Labview 2010 IMAQdx converting
I'm working on converting a program from Labview 8 to 2010. I couldn't use the Legacy drivers because I'm using Windows 7-64 bit, so I'm reconfiguring the IMAQ vi's to IMAQdx vi's. I replaced the vi's and ran the program and I get the following error:
Error -1074396120 occured at IMAQ Linear Averages
Not an Image
Possible reasons:
IMAQ Vision: (Hex 0xBFF60428) Not an Image
I can't post the full code, but I can post the section about acquiring the Camera Images, where I believe I get the error comes from. Any help would be appreciated!
(3,460 Views)
This board is not for code discussion or driver upgrades. I suggest posting to the vision board.
(3,455 Views)
Sorry if I'm not doing this correctly, but couldn't someone still convert the labview 8 version I posted? Or does it need to be a complete vi in order to be converted?
If so I will then post in the vision board.
(3,453 Views)
LabVIEW 2010 will open VIs written in LabVIEW 8.  So there's nothing to be done in this board.  I asked the moderator to move this thread to the LabVIEW board.
(3,442 Views)
