Labview 8 with 4350 DAQ board
I upgraded from LabView 6 to Labview 8.  At the same time, I put the old 4350 board into this new WinXP computer.
The board works great in MAX, but LabView can't seem to find it.   And can't use all of my old data acquisition VIs.
According to MAX, I have both the mx and legacy versions of NI-DAQ
What else do I need to check?  or is all of this in incompatible combination?
(2,537 Views)
Hi Todd,
You probably have an older version of the Traditional NI-DAQ driver. In order to use that hardware in LabVIEW 8, you will have to have the latest version of the traditional NI-DAQ driver - 7.4.1.
I hope this helps.
Natasa
(2,517 Views)
