Labview Application Hangs When Upper-left Menu is Clicked
I have an compiled Labview executable with multiple open front panels.  When you click the upper-left corner of any window (usually drops with a menu for Restore|Move|Size|Minimize|Maximize|Close), the entire application freezes and can only be recovered by ending the process in the Task Manager.  Any ideas?
Joe
(2,551 Views)
Do you have any sort of event structure in your code that's monitoring menus? What happens if you right-click the window's title bar?
(2,548 Views)
