Labview + Arduino + Linx + DS18B20 Temp VI ?
Does anyone know of a VI that will work with Linx/Labview 2018/Arduino, and the DS18B20 temp sensor (one wire sensor)?
(7,413 Views)
As far as I can tell, the DS18B20 temperature sensor uses a one wire interface with the Dallas protocol.  For using it with L abVIEW, take a look at the following add-on.
https://www.ni.com/en/support/downloads/tools-network/download.onewire-utilities.html
As for the arduino, have you taken a look here?
https://www.pjrc.com/teensy/td_libs_OneWire.html
DillonL.
(7,382 Views)
Dillon,
Appreciate your help.
You are correct.  It is a Dallas one-wire protocol.  I did chat with Colin from Interface Innovations and they have some wonderful tools that can be used to read/manage one-wire devices on a variety of interfaces.  However, they do not have a Linx VI for reading a one-wire device.
The other link has the Arduino config/code for reading a one-wire device.  I can already read the one-wire device directly from the Arduino but I would really like to read it through Linx/Labview.
I will keep experimenting with creating a Linx custom VI.
(7,374 Views)
Hi Jeffgg,
I am not aware of a prebuilt solution in Linx for this, however I would post your question over on the LabVIEW Makerhub and see if anyone there has any thoughts.
https://www.labviewmakerhub.com/forums/viewforum.php?f=12
DillonL.
(7,362 Views)
hi
i want to do that with raspberry pi and is not run can u help me ?
(3,793 Views)
