Labview Arduino toolbox & linux
Ciao,
Is it possible to use VIPM 2014 with Labview Run Time Engine 2014?
On a Linux PC I have Labview 2014 installed and would like to use the Labview Arduino Toolkit which seems to be installed via VIPM. On running ./vipm in the apprpriate directory the error below is displayed:
Can't find library liblvrt.so.13.0
Make sure this library is installed in your LD_LIBRARY_PATH
search path, or in /usr/lib
Can the 2014 Labview Run Time Engine be used instead or is it possible to install the Labview Arduino Toolkit manually?
Best regards
Message 1 of 1
(3,052 Views)
