Labview Built Executable - Long Runtime Startup Time
    I made the config file and it works great. However the area I work in has alot of application and I would prefer a modify the registry to perform the same function. I am also assuming that there is a equivalent registry vale that does the same thing. This way all the applications with get the benefit and the developers would would not have to do anything.
   So is there a equivalent registry key performs the same function?
Kaspar
Message 11 of 14
(1,575 Views)
I haven't looked at any further solution regarding this. It is inconvenient to create the config file but that seemed to have solved the problem. I don't work on that application anymore.
Message 12 of 14
(1,567 Views)
   Thanks for getting back to me. I put a call into the Labview support line and have also called the local labview support person. If I find a  regestry key that does the same function that the config file does I will post it to this forum
Kaspar
Message 13 of 14
(1,560 Views)
VeeJay, that article seems to have solved my issue too.
I used the config file method.
Message 14 of 14
(1,475 Views)
