Labview Canopen Heartbeat
I have been configuring CANopen communication between crio-9014 and epos4 drive. I want to add Heartbeat protocol to my communication algorithm. But, I have 2 main questions;
1) In heartbeat mechanism, If one node is the loss of communication, would whole communication be stopped or just that node be stopped?
2) Should I read heartbeat in the main loop where I read and write my PDOs or should I create parallel  loop to my main loop ?
(3,918 Views)
Accepted by topic author BURAK_AYDIN
Only the failed node be stopped.
There is no restriction about the position of the read heartbeat. But a shandalone loop could support the efficient check.
Additional, do you use the NI 9881 now?
Thanks!
(3,906 Views)
First, thank you for your answer.
Yes, I use NI 9881 module right now.
(3,884 Views)
