Labview_Concatenate Strings Function
Hi, I'm using the Concatenate Strings Function and the output is writing the wrong string. I absolutely don't know what to do with it.
(1,914 Views)
Your "output hexadeximal" seems to be a string that is using the normal display style not Hex:
Spoiler
Redhawk
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
(1,906 Views)
Don't use Type Cast to convert numbers to strings!
Use the proper number to string primitive in the Number/String Conversion Palette
=== Engineer Ambiguously ===
(1,884 Views)
