Labview Core 2 Ex. 4.2 Issue
Not sure where I've gone wrong here. Firstly when I open the VI it looks different then the picture supplied, step 1 tells me to right click and change a property node however there's nothing to right click to change.
(2,046 Views)
Hi AD,
Did you read the steps correctly?
Did you notice step 2? It clearly says: "modify the block diagram…"! (That explains why the block diagram looks different than is shown in the exercise!)
(2,041 Views)
Correct I read that also however that doesnt really show me what functions I need to add, I havent seen those before. For ex. below it tells you more or less exactly what needs to be done.
(2,032 Views)
Accepted by topic author AltiumDesigner
Hi AD,
You need to add a property node (use Quickdrop!). Then do what bullet item 1 says about linking…
Bullet item 3 also is a property node, while item 4 is an invoke node
(2,022 Views)
@GerdW wrote:
Hi AD,
To be fair, I tripped over my tongue the first time an exercise referred to stuff I did in the exercise before.  I didn't realize it was a work in progress.
Bill
CLD
(Mid-Level minion.)
(1,993 Views)
