Labview Crashes
i don´t have much experience in LabView and borrowed much of my code. Now my software crashes
once every month. In my oppinion this is caused by an failed update at least it looks like that
in Windows Event Viewer. I think that some Part of Ni Software tries to get an update but because
it isn´t connected to the internet it tries LocalHost and there, of course, no data is located.
This produces about 100 errors in one minute and after that the Software isn´t working any more.
All of the errors in Windows Event Viewer look more or less like this:
Source:LabVIEW
Event ID:3299
Task Category:None
LabVIEW information: Error: 404 "Not Found" for "/"; file "c:/program files/national instruments/shared/ni webserver/www/": Can't access URL .
The request path always starts with  "c:/program files/national instruments/shared/ni webserver/www/".
Does someone have an idea. One day of intensive googling didn´t help.
Thank you
chef_koch
(3,067 Views)
Hello there;
What LabVIEW version are you using??
There is a known error when migrating code from LabVIEW 8.6 to 2009 due to the fact that they use different relative paths.
If you are using a remote fron panel you can try the following
Greetings
(3,006 Views)
