Labview DAQ channel wizard
I followed instructions in the Labview manual to access the DAQ channel wizard. For some reason I am directed to the device & automation explorer instead. I have Labview 5.1 installed on windows 95 system.
(2,874 Views)
Hello;
You are probably being pointed to Measurement and Automation Explorer to have your hardware configured.
MAX is the Software that allows you to configure your hardware and set some virtual channels up.
Regards
Filipe A.
(2,874 Views)
