Labview DSC Bound Shared Variables logging different values?
I have a system where a "server" application will pull values from a data logger and write them to a library of shared variables (labview 2017 sp1 DSC runtime only on all machines). I have several "client computers" who have libraries of variables that are bound to the "server" to distribute the data.
When I extract the data, the numbers are not always the same between the server and client libraries. There is no rounding going on, it's published with 1 decimal point from the server, but the "server" and "client" variables are often 0.1 apart... it's not a lag where maybe the "client" is behind one or two updates, its a totally different number the server never published....
Has anyone come across this or have an explanation for it?
(1,517 Views)
Hello Cannuk
may i know more details and code ?
I have worked with same project.
Regards
asif
(1,359 Views)
