Labview Data Acquisition
Depends on how many MFCs you plan to control, and whether you want to do more than just change the setpoint.
Many of the NI multifunction DAQs have 2 analog outputs. Some have none. If you want 4 analog outputs I think you will need an AO-only board.
The good news is that MFCs are slow enough that pretty much any sampling rate will be OK. 8 bits might be adequate precision and 12 bits should be plenty.
Message 11 of 12
(617 Views)
It also looks like you could use the digital I/O of any number of DAQ boards and connect them to the TTL interface. You usually get a minimum of 8 and a very inexpensive DAQ device is the USB-6008 with 12 digital I/O, 2 analog out, and 8 analog inputs.
Message 12 of 12
(607 Views)
