Labview Display message and control Value
Hey,
I am making a program and I have got some problems, how can I display a message if I use poor button? ( the button is Num Ctrl).
Moreover I would like to control value (X) between 0 and a other value (Y) who can be modified during simulation, So I would like that 0<X<Y> Have you got any ideas ?
Thank you very much for you answers
Kind regards
Meratus
Message 1 of 11
(4,741 Views)
@Meratus wrote:
Hey,
Kind regards
Meratus
What do you mean Poor button? For numeric control, you can use the property node "Minimum" and "Maximum" during the run time.
Message 2 of 11
(4,731 Views)
Thank you for your answer ! Poor=The wrong button ! Yes i think to use maximum and minimum. But it is not possible in my case, i need to display it is wrong when we push a value in the num ctrl.
Message 3 of 11
(4,715 Views)
You can use a value change event for the so called "wrong button" and pop-up a message when the event executes. Why are you saying its not possible?
Message 4 of 11
(4,712 Views)
In fact i have 8 num ctrl and i have 4 scenarios in the same program ! For exemple in the scenario 1 i use just 2 buttons and i would like when i use the other buttons, disply a message of error " you do not use the good button"
Message 5 of 11
(4,704 Views)
Instead of displaying the message why don't you disable them so that the user automatically knows they cannot use it. Does it make sense?
Message 6 of 11
(4,696 Views)
How can i disable them ? It is perfect if i can
Message 7 of 11
(4,694 Views)
Right click the Control/Terminal>Property Node>Disabled, Here you can select the "Disabled and Grayed out".
Message 8 of 11
(4,689 Views)
Thank you ! But i need to change the value if i change of scenario
Message 9 of 11
(4,687 Views)
You have the properties available (Check the properties of thee control) so you can do whatever you want.
Message 10 of 11
(4,684 Views)
