Labview Driver for Temptronic TP0412A?
Is anyone aware of any labview drivers for a  Temptronic TP0412A Temperature forcing system. It is GPIB controllable, but I have not seen anything coded in labview.
Thanks very much
Regards
Barry
(2,862 Views)
Hey Test_head,
Normally, any of the instrument drivers that we make are found at http://www.ni.com/idnet . I've taken a look, and there doesn't seem to be any instrument driver for that instrument made yet. Something I would recommend taking a look at is using the labVIEW<->GPIB.vi example, and using that to build your program from. To get this example, just open labVIEW go to Help->Find Examples->Search for "GPIB"->And choose labVIEW<->GPIB.
This is a simple program that get's the communication going back and forth, and you should be able to copy and paste the VI's in the order you want, using constants for the commands, and the instrument communication could be built from that.
Good luck!
Nick D.
(2,836 Views)
