Labview Drivers for Wireless Sensor Networks
Hi Nutkani,
Habe you got it working with MIB600? I am currently trying to interface that device using Labview.
Could you please share what have you been up to?
Message 131 of 154
(2,656 Views)
Hi,i'm using MDA100cb nodes and may i know how to read the data from it?i'm using MIB520.
Message 132 of 154
(2,609 Views)
The MDA100cb is not one of the devices supported in the driver
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=1FB66B354ED149C7E0440003BA230E...
Message 133 of 154
(2,603 Views)
Hello Ryan,
I am trying to read the data from two nodes (MicaZ) with two MTS 300 Sensor boards and plot the returned data using "Read Data Display Health.vi" in the Crossbow driver folder. After a few minutes of plotting, I can see that the data for two nodes gets mixed up. For example data of node 1 is assigned to node 2 and vice versa. May I know the reason of this and how to solve the problem?
The other question is that: In the program in several VI's there is number of nodes and number of point. Wat is the diffrence between Node and Point?
Thanks for your help in advance!
ShK
Message 134 of 154
(2,566 Views)
Hello Ryan,
ShK
Message 135 of 154
(2,566 Views)
Hello Ryan,
ShK
Message 136 of 154
(2,566 Views)
It looks there is an answer for you here: http://forums.ni.com/t5/Wireless-Sensor-Networks/crossbow-Labview-help/m-p/1136999?requireLogin=Fals...
CLD Certified
Message 137 of 154
(2,544 Views)
Thank you!  Yes, I posted this question before recieveing the answer from Patricia .
Message 138 of 154
(2,537 Views)
Message 139 of 154
(2,536 Views)
Hello, i am studying on the crossbow xmesh driver and try to run the example read data and display health. However, the gataway visa resource cannot dectect the COM4 for MIB520. The port driver has been installed and port number can be seen in device manager in Windows. I am using the iris mote and MTS400/420 sensor boards.
In addition, when i try to run the example, it pops out Error 8003 occurred at WSN Send Generic Stream Message.vi.
Can anyone help me with that?
Thank you.
Message 140 of 154
(2,411 Views)
