Labview Error 200477 - AutoDAQ.vi not displaying properly
Hi Uday, yes it seems that the 2011 version of matlab is works but the 2015 does not.
Are there also year-specific drivers?? Thanks!
Message 21 of 24
(1,268 Views)
@BeachManMan wrote:
Hi Matt,
    I have MAX downloaded, but how could I confirm if it is a hardware problem with this? The "active" light on the card chasis is on but not the ready light and the NI DAQ card was just calibrated so that should be good too. I'm currently checking if I can get this code, thank you.
Open max, select your device from the devices and interfaces pull down then select test panels create a task to test the device.  The link below should be helpful.
Test Panels Example
-Matt
Message 22 of 24
(1,257 Views)
Hi Matt,
    Yes, I've confirmed through the MAX software that both the Card Chassis and Module are working correctly. I'm currently chasing down the original author for the labview program as well.
Message 23 of 24
(1,228 Views)
Hi Beach,
At this point i think we may need to see some code.  Did the .exe come with a readme file or an installer? Id be curious to see the file structure that the .exe folder.
-Matt
Message 24 of 24
(1,215 Views)
