Labview Executable digital I/O problem
I am attempting deploy an executable which uses some digital and analog I/O. My hardware is all working and my analog and temperature cards are working. I don't think I have the task created correctly to utilize the digital input card or the digital output card.
In my block diagram, I used the daq assistant to run the I/O. When the hardware is connected to my PC everything works. When connected to the deployed PC the digitals do not work. Is there something else I need to do to initiate the task on the deployed pc, and is it done in NI Max or in the block diagram of the executable?
(2,108 Views)
Most likely, you problem is that your DIO card is not named that same between your two machines.  You can fix this in MAX.
In my opinion, a better option is to not use the DAQ Assistant and use the actual DAQmx API.  Then you can do things like read the port and/or channel name(s) from a configuration file to set up your task.
(2,099 Views)
Excellent, that was the problem.
(2,070 Views)
