Labview FPGA, Array Subset Missfunction/Bugreport
Not shure if I am in the right place for this, let me know if not
The FPGA code below returns following Error, when generating Intermetiate files.
"LabVIEW cannot determine the size of the array output because a node input is a non-constant value.  Ensure that all index and length inputs resolve to constant values."
Why? The size is always 17? Size of Input array ist 64. Possible Indexes are 0, 20, 40.
The length, yes I agree! But why I'm not allowed to choose the index?
The VHDL/intermediate File translation should be somethig like
if select = 1 then
   out <= in(16 downto 0)
elif select = 2 then
  out <= in(36 downto 20)
fi
Is there any nice Solution for this? In general how to get a subset from a unsigned integer in the most efficient way?
Martin
Using:
Labiew 17sp1
vivado 2015.4
sbRio9651
(4,259 Views)
Duplicate some Code and it works! code below is ok!
But still, the reason for this is still not clear for me...
(4,246 Views)
Static array index as opposed to non static makes all the difference.
(4,232 Views)
except array size & array index none other functions re supportable
(2,661 Views)
Not true. With static-length Array inputs and static indices, "Build Array", "Array Subset", "Delete from Array" and so on are perfectly fine on FPGA.
(2,656 Views)
