Labview FPGA Beginning Programming Suggestions
I'm just becoming familiar with LabView for a new job. My company recently purchased the PXIe-1062Q chassis and the FlexRIO FPGA module with NI 5752 adapter.
I've been asked to work on the programing of the FPGA for our lab's use. Does anyone have any suggestions of where would be the best place to start for an introduction?
Is LabVIew FPGA the same as LabView, or are they different enough that I should just start with LabView FPGA given that the end goal is using that?
Newbie to Labview
(2,912 Views)
Hi!
I would suggest starting with simple, plain Labview.
Here you can find a starting point:
https://learn.ni.com/learn/article/labview-tutorial
When you've understood the basics of Labview programming you can switch to Labview FPGA.
Here you can find some material:
https://www.ni.com/en/support/documentation/supplemental/18/labview-fpga-getting-started.html
Hope this helps,
Marco
(2,891 Views)
