Labview FPGA Compilation error for NI-5753 with FPGA target PXIe-7962R
Hi. I'm getting an error when trying to compile the NI 5753 (AC) - Getting Started example for an FPGA target PXIe-7962R.
I also have a NI 5753 (AC) with a FPGA target PXIe-7976R in the same chassis and for this target the compilation works correctly and everything works just fine, so I guess everything is ok with my Labview version and license. Also, I can compile other example projects for the FPGA target PXIe-7962R which are not related with using the adapter module NI 5753.
Is there anything I can do to be able to compile and use the NI 5753 with my PXIe-7962R?
The error obtained is bellow:
An internal software error has occurred. Please contact National Instruments technical support at ni.com/support with the following information:
Error 7 occurred at niFpgaTopLevelGenCallTargetSpecificVI.vi<-niFpgaHandleConstraintsAndMiscFPGAFiles.vi<-niLvFpgaTopModGen.vi<-niLvFpgaTopModGen.vi.ProxyCaller
Possible reason(s):
LabVIEW: (Hex 0x7) File not found. The file might be in a different location or deleted. Use the command prompt or the file explorer to verify that the path is correct.
Nonexistent GPIB interface.
Attempting to copy a file "C:\Program Files\NI\LVAddons\flexrioii\1\Targets\NI\FPGA\RIO\79XXR\Common\FpgaFiles\DramASx50t\dram32IntfA.ngc" that doesn't exist. in C:\Program Files (x86)\National Instruments\LabVIEW 2024\resource\RVI\StockIO\private\topModGen\niLvFpgaTopModGen.vi
(637 Views)
7962R is a virtex 5 requiring ISE for compilation.
The other is a Kintex 7 card requiring Vivado for compilation.
Double check your installed compile tools and make sure you have both installed.
(581 Views)
Hi, thanks for your reply.
I'm aware of that difference, but it shouldn't matter because I'm using NI Cloud Compiling. I have already compiled other projects for 7962R using NI Cloud Compiling. It just didn't worked for the NI-5753 with FPGA target PXIe-7962R.
(557 Views)
