Labview FPGA: Unable to output sine wave to oscilloscope through analog output
Hi guys, would appreciate your help with my problem. Have been wrecking my head over this problem.
I am currently using a PXI 7852R Multifunction Rio connected to a SCB 68 (connector block) and am unable to output a sinewave I have programmed using Labview FPGA module. As I am an undergraduate and am new in this field, please forgive my ineptness toward this subject.
I have looked through the forums previously and tried implementing certain stuff suggested, converting the output of the "sine wave generator" to a fixed point integer and then to the Analog output (AO 0) of my connector block. And finally using a oscilloscope to measure the analog output (voltage). However, for the past week, I am unable to observe anything through my oscilloscope. I am sure my oscilloscope is working properly as I have troubleshooted it using test signals.
I have also tried troubleshooting the past week by connecting AO1 to AI0 to also test the functionality of my Analog output. But I am still unable to detect anything significant or correct.
Would appreciate you guy's input. Many thanks in advance from Singapore!
I have attached my LABVIEW FPGA codes and other relevant pictures for your viewing.
(3,458 Views)
Why do you convert the signal to 16,4 format before writing tot he AO node?
(3,424 Views)
Hi Intaris,
I have removed the FXP conversion and now my code works, I am able to output the sine wave as desired. I thought that the FXP conversion was necessary as I observed the others do the same. However they used a compact Rio and an AO attachment while mine is a multifunction rio with a connector block. Perhaps that was the difference..
(3,416 Views)
Thank you so much for your feedback, Intaris!
(3,414 Views)
You should look at the datatype of the output node.  If it is I16 (which it seems to be) then it expects numbers in the range of -16384 to +16383. Changing this data to a number between -16 to +16 will of course not yield the same result.
Maybe you should have a look at some of the basic turorials on how to program LabVIEW.
(3,412 Views)
