Labview FPGA called another software component
Hi
I am trying to compile my FPGA code which has previously compiled. I get this error.
"Labview FPGA called another software component, and that component returned the following error:
Error Code: -52009
NI Platform Services: The requested resource has been marked for deletion and is rejecting new requests."
What is this error code?
(6,196 Views)
Anyone have any ideas on this?
(6,148 Views)
I've been looking in to this for you today - unfortunately, that seems to be a really rare error code which doesn't come up very often on our systems, so there's no quick fix that I can find.
A couple of options:
1) Have you made any changes to the code recently, in terms of updating it from an earlier version of LabVIEW? If so, it may be worth mass compiling your project up to the latest version in case there are references to software components which no longer exist.
2) It's probably worth a try repairing your LabVIEW, FPGA and RIO drivers installations from disk, as described here: http://digital.ni.com/public.nsf/allkb/FE6B641E86E55AF2862576DE00038001?OpenDocument
This could be due to some kind of missing or corrupted component in, for example, the Xilinx Tools
3) Are you referencing any kind of external software, such as DLLs or third party instruments, in your file?
4) What hardware are you using?
Please let me know how you get on with these queries.
Best wishes,
Chiara A
Applications Engineer with NI UK & Ireland
(6,137 Views)
Hi
The code is unchanged.
I am also getting errors in Measurement and Automation explorer .
VISA error 0xBFFF0000 (VI_ERROR_SYSTEM_ERROR)
I have tried uninstall and reinstalling VISA but no change in the Error.
I have repaired all my installations.
My hardware I have is USB-6211
PCI-7830R
PCIe-7851
These don't appear with options in Measrement and automation explorer just that they are present
(6,127 Views)
Hi Zepp,
Are you using Windows XP Embedded by any chance?  Or some kind of custom operating system?
I've found a couple of references in the past of that VISA error being due to missing components in the OS itself.  Since the original error is usually related to 'things being marked for deletion' (as in the other thread you commented on about this) I'm wondering if there's something missing on the OS side which makes LabVIEW think VISA isn't there.
Best wishes,
Chiara A
(6,097 Views)
Hi
I am using standard Windows 7
(6,092 Views)
Can you give more details about the Target and the software.
(6,075 Views)
