Labview FPGA compile using NI App Builder API: Build.vi
Hey,
I'm having trouble starting compilations for FPGA targets (I have the modules installed) using the NI_App_Builder_API: Build.vi method which looks like it only needs a spec to build. Has anyone else had success with this?
I also have tried niFpgaBuild_GenerateCode which also has an error (I can build the FPGA fine manually). Any ideas?
Rik
(3,262 Views)
Hello Rick,
could you please describe (post) your Error codes?
Like that we will have a better idea (description) on what you want to do.
James.
Greetings and Regards,
James
(3,191 Views)
