Labview Filter design
 I am trying to design a filter to replicate the frequency weighting curves in ISO-2631-4.
These curves are specified (in third octace steps) between 0.1 and 400 hz
I have based my design on the "DFD least Pth Norm Design.vi"
I have created the band specification array but in my vi I do not appear to be getting anthing out of the "DFD Get Freq responce.vi"
Any thoughts
I quite new to filter design,  Am I using the right technique? If not how should I be implementing this filter?
Attached is my vi
P.S. also postted this on the PXI messageboard in error
(2,784 Views)
Hi, Actually, you use the design VI in the right way. The reason that you didn't see anything is that the DFD Get Freq Response VI need a "freq points" input. If you don't want to input the freq points array, you should use DFD Plot Freq Response VI. I attach the modified VI below, hope it helpful.
(2,756 Views)
