Labview Flex Rio PID example
Is there an example to use the canned FPGA PID vi in flex rio devices? I have tried to use this vi from the pallet, but every attempt has resulted in errors.
Daniel
(1,706 Views)
I'm using flexrio with PID right now, it great, everything runs fine.
You only need to make sure the PID function is running at non-sctl loop, also make sure the input of the PID is SGL.
(1,612 Views)
