Labview Graph Problem
I have a problem with a tool witch takes excel columns and plots graphs.
The problem is that when i create the png of the graph it additionaly appears the poit (0;0) witch should be on graph.
In the preview i can't see this point. I attached an example.
(2,650 Views)
Have you tried putting a probe onto the data going into the graph to check there aren't any extra data points (i.e. at 0,0)?
(blog)
(2,627 Views)
