Labview - Graph
May I have another question to this topic?
I need to connect a 100 ohm resistor in series with the diode.
How can I do this in LabView? I browsed the Functions drop-down menu and I haven't found a resistor.
The resistor is necessary to set the bias point of the diode.
Thank you very much in advance!
Message 11 of 15
(1,356 Views)
I have another question - what kind of LabView block is the one marked by the red circle?
Thank you very much!
Message 12 of 15
(1,341 Views)
LabVIEW is a programming language, not a circuit simulator (NI makes Multisim and Ultiboard for that).
You can model electronic circuits with math, but you can't simulate actual components.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 13 of 15
(1,337 Views)
That VI is Get Waveform Components from the Waveform palette.  It separates a waveform into its components:  Start TIme, Delta T and an array of Y points.
Altenbach used it to extract the Y array so he could perform math operations on the datapoints.
Message 14 of 15
(1,334 Views)
Thank you all!
Message 15 of 15
(1,316 Views)
