Labview IMAQ VI for capturing images and saving with incremental file names
Hello, I am using LabView 7.1(IMAQ) to capture images with NI's PCI 1426 card, and a JAI CV-M2 camera. Now, with the example VI's like LL Grab, or LL Sequence, or Snap and Save to File.vi, I can capture the images. But what I actually want is to capture images continuously and keep saving them with a sequentially incrementing file name.
I have tried to modify the Snap and Save to File.vi  by adding a 'for loop', so as to run this for required number of images. This works okay, but I can't really change the file name after every image. However, I'm not confident with this method either. I think it would be better to use the buffer itself, as is given in LL Grab.vi and somehow save images from the buffer. I think this would be faster ?
In any case, any ideas as to how I should go about implementing auto-incrementing of the file name ?
Any help will do.
Thanks.
- Prashant
Message 1 of 11
(15,223 Views)
Something like that:
Андрей.
Message 2 of 11
(15,214 Views)
Thanks a lot for replying.
I tried using this in the VI i was working with, but using the "build path" vi doesnt seem to work. If I use just the base path from user's input, it works, but then again it keeps overwriting the images into one file rather than giving each file a new name. I'm attaching the vi.
Please take a look and tell me where i'm going wrong.
Thanks again.
Message 3 of 11
(15,208 Views)
You should select target folder instead of file (well, you can also strip path, but its not good from usabillity point of view). Also, something like that:
Message 4 of 11
(15,202 Views)
Thanks a lot for this. This works. And using this in the LL grab.vi I can at present capture images and save them as I wanted. However, the framing rate I get with this is a mere 2 fps (this is higher than when I tried with LL Sequence.vi in which case it was a disastrous 0.5 fps).
Is there a way to increase this to realize the camera's full potential, as I am guessing that writing on a buffer (onboard memory) seems to work better than continuously writing onto the system memory.  Maybe i can write onto the ram for increasing the speed ?
Thanks a lot again 🙂
Message 5 of 11
(15,174 Views)
I download LL Seqence.vi, but there are  a couple of files i can't load, like IMAQ WriteFile, IMAQ Snap.vi etc. I have labview 8.2 and NI Vision Acquisition Software 2011. Anyone can tell me where i can get these files? Thanks
Message 6 of 11
(14,636 Views)
Usually, IMAQ Writefile and IMAQ Snap both get loaded when you install vision on your system. They should be found at-
Vision and Motion>>NI-IMAQ>>Snap    and
Vision and Motion>>Vision Utilities>>Files>>IMAQ Writefile
However since these seem the be missing , I checked the compatibility between LabVIEW 8.2 and Vision 2011. They are not compatibile.
Use this link to download http://joule.ni.com/nidu/cds/view/p/id/1524/lang/en Vision 2009.
Once you install this, you should be able to use the VI in the thread
Hope this helps
Kanchan Bhakoo
Applications Engineer | National Instruments
Message 7 of 11
(14,611 Views)
I already did that, thanks
Message 8 of 11
(14,606 Views)
Could you upload the VI for this or teach me how to make out what is what from a snippet.
Message 9 of 11
(13,231 Views)
I have applied the IMAQ Write File2.vi to save the images in LabView 2012, now there is a problem  when I run it:
error IMAQ vision: Invalid parameter. I checked the code and don't find the reason.
Do you have some suggestions? Thanks a lot.
Chen
Message 10 of 11
(7,766 Views)
