Labview Installer Problem with FPGA project DAQmx System Monitor Hardware
I have a FPGA project which is developed in a PXI system with Windows XP (under LabView 8.6 and LabView 2009). The following hardware are used
A) 7833R PXI card, B) 4461 DSA card and C) System Monitor 8250 card. The code is completly error free. We have checked the functionality several times and it is stable.
We are NOT ABLE TO CREATE THE INSTALLER for the above to run in an exactly similar PXI system.
Please provide help in this matter.
(3,081 Views)
1) Usage of LabVIEW FPGA Reference may create issues, therefore, you may need to change the reference to a Bitfile rather than a VI.
Kindly note ID 42189 - Cannot build installer if host VI references FPGA VI in the following link -
https://www.ni.com/en/support/documentation/bugs/09/archived--labview-2009-and-2009-sp1-fpga-module-...
2) Breaking of the VI when we build applications, is related to a Patch. Note ID's - 173387 and 175141.
 There is a patch - LabVIEW 2009f3 That requires to be installed to overcome this problem. Please find links below.
https://www.ni.com/en/support/documentation/supplemental/17/archived--labview-2009-f3-patch-details....
Path to Download Patch - https://www.ni.com/en/support/downloads/software-products/download.labview.html#359435
(3,056 Views)
