Labview Intensity Graph Vertical Axis Label
Im actually not familiar with the counterclockwise operation that you referred to. In fact I had first looked for something like that when I first came across this bizarre problem. I wasnt aware that you could rotate text labelsSmiley Surprised. Can you point me to where I can find this function?
Message 11 of 29
(2,263 Views)
I probably posted too many times and this part got lost somewhere while you were reading:
"You can right click on the free label and use the counterclockwise operation to rotate it so that it appears in the correct orientation..."
Here are a couple screenshot to help you as well!
Best,
JLS
Sixclear
Message 12 of 29
(2,253 Views)
Ah yes, Thanks for the help! As many years as I have been using Labview now, Ive never even looked at that vertical arrangement menuSmiley Surprised.
Message 13 of 29
(2,252 Views)
No problem,
To be honest, that was the first time I thought to use it 😉  Anyway, it seems as though if I recreate the intensity graph, I don't see the same problem... I am wondering if somehow your instance of the intensity graph has become corrupted, however subtly.  It looks like you just made the background transparent, and the graph area white... when I actually create a new instance (and even make these changes) then the label seems to behave appropriately (and not like we see with your instance).  Can you try dropping another instance of the intensity graph on a front panel and see if you experience the same problems?  If so, this will be a really interesting thing to try to figure out, because it may mean that somehow a single feature of the intensity graph has been corrupted on your machine... perhaps a repair of LabVIEW from add/remove programs might help.
Anyway, worst case scenario is the workaround, but the behavior is interesting!
Thank you again,
Best Regards,
JLS
Best,
JLS
Sixclear
Message 14 of 29
(2,248 Views)
I have also a problem about vertical label. But it's not in intensity graph.
I am using picture control to draw some plots.
Is there any way to rotate the text label (to vertical) in a picture?
Thanks!
Message 15 of 29
(2,227 Views)
I actually didnt realize this feature either but its been around for a while now I guess...
If you right click a generic text label, and go to vertical arrangement and select clockwise/counterclockwise, you can rotate the text label to replace the problematic labels in some of the controls. I think the labels are pretty stable until you start to screw around with the properties of the particular control/indicator. But the text label rotation does provide a work around. Good luck!
Message 16 of 29
(2,224 Views)
How about the text inside a picture?
Can I "draw" a vertical text?
Message 17 of 29
(2,220 Views)
Im not too versed in labviews picture controls so Im not sure what you mean by "drawing vertical text". You can certainly create a text label and drag it into the picture but it sounds like you are trying to do something more elaborate?
Message 18 of 29
(2,218 Views)
I am drawing a coordinates in "picture control". I want to add labels for X and Y axes. I can use "text to position" to put such a label. But I can't rotate it for Y axis.
I need some simple way to get a vertical text. And I don't want to rotate the whole picture.
Any suggestion?
Message 19 of 29
(2,216 Views)
Can you attach an example of what you are doing?
Message 20 of 29
(2,214 Views)
