Labview Interfacing microcontroller
Hi
I have viewed numerous form having discussions on interfacing between LabVIEW and microcontroller and most of the discussion concluded on using UART as a viable option. I have the same question but I don't wanna use UART as the communication medium.
Basically, I wanna control a motor operated wheelchair using LabVIEW software. I can't communication using UART to the wheelchair because I would have to drag my computer with the wheelchair. The data acquisition board provided by Labview like myRIO,compactRIO are pretty expensive and I wanna go cheap.
What would be the cheapest and wireless communication technique between computer and wheelchair? Thanks in advance
Regards
Ammar Naseer
(3,931 Views)
There are a few options to use Arduino and Raspberry Pi microcontrollers with Labview. Look into the LINX toolkit for Arduino, and look into MakerHub toolkit for Raspberry Pi. I think there were a couple of other toolkits for Raspberry Pi but the names escape me at the moment.
(3,908 Views)
Thanks for the reply
I thought that through but the same problem lies instead of using UART I would be stuck with USB cable connecting my LabVIEW with Arduino.
If I am thinking straight.
(3,892 Views)
LabVIEW is software.  An arduino is hardware.  How do they connect using a USB cable?
The suggestion is to use an Arduino and/or a Raspberry PI has your hardware.  Smaller, inexpensive pieces of hardware than a PC.  You might use a PC connected to them via a cable (USB or serial) to program them.  But once that is done, the programs running on them will do what you programmed to do.
(3,874 Views)
I didn't know that the program created on LabVIEW could be uploaded on an Aurdino. I thought as long as PC (running LabVIEW code) is connected to the cable Aurdino reads Labview software and when the USB cable is disconnected it won't work.
(3,858 Views)
It can't.  What Linx did was create canned sketches that can run on an Arduinio which a LabVIEW application can communicate with over a UART connection.
I know some people have managed to get a LabVIEW application to run on a Raspberry Pi, so that might be an option for you.
(3,842 Views)
Use an Arduino and the UART with Bluetooth modules ;like the HC-05 and HC-06.
Once you setup and pair the Bluetooth modules they install a virtual serial port and become transparent
Communication with the Arduino (using LINX or not) is just like communicating with any other device on serial port.
=== Engineer Ambiguously ===
(3,829 Views)
