Labview Load Code Error 3 at LV 2014
Hi All,
I got message error code 3 when open my vi and does not have the file's backup.
How can I fix this problem?
Thanks before,
Regard
here's the crash vi
Message 1 of 11
(5,753 Views)
Please simply attach your VI to your post here.
Don't host it on some third party site peppered with ads and deceptive links. Very annoying! Thanks.
Message 2 of 11
(5,724 Views)
Thank you very much for reply.
I am very sorry, Sir. My bad. I just don't know where I have to upload my vi file. I have tried many times waiting for hours to upload directly here. But never success. So a friend told me to upload there. Once again, I'm very sorry.
Regard,
Message 3 of 11
(5,711 Views)
Regard,
If you are using Firefox, use a different browser. I had problems using Firefox to attach a VI.
Message 4 of 11
(5,705 Views)
Regard,
I'm using Google Chrome as browser right now.
Should I try another one? Would you tell me what browser?
I'm new in discussion forums and my english is not that good (bad). So, I apologized for that.
Thanks.
Message 5 of 11
(5,699 Views)
I am using chrome and have no problems. It could be a firewall issue from your company, for example.
In any case, I refuse to download from your link. First of all, I won't sign up for "premium downloads" and I won't use any of my social netowrking logins for the 20 second delayed download. Besides, there are so many deceptive ads with fake "Download" buttons that would download other things that I stay far away from any of this. Sorry.
Of course if the front panel cannot be loaded, it probably got removed at one point. there is no way to recover it.
Message 6 of 11
(5,681 Views)
The first link suggests that the VI is >30MB (I also did not download it).   Might that be part of the problem?  Could the OP be running out of memory while loading? Try loading on a different computer (probably not a bad idea regardless)?
Is it be possible to open a reference to the VI and delete decorations, default values for charts, etc, to get the VI size down and see if it could be opened?  Opening the ref brings the entire VI into memory, I believe, so if it's a memory issue there may not be any relief there.  May be worth a try, though.
Message 7 of 11
(5,667 Views)
Sure, I understand. Thank you.
Best Regard.
Message 8 of 11
(5,646 Views)
Hi, Zwired1
I believe you're right. My VI is 31,1 MB. It contains some image. Unfortunately, I can not open reference to the VI.
What about compressing the file?
Best Regard.
Message 9 of 11
(5,639 Views)
Do you get an error when you try to open a reference (if so, what)?
Compressing the file does not really apply here.
Are the images in your VI pasted onto the front panel/block diagram or are they set as the default values for picture controls, etc.?
Have you tried opening the VI on another computer, preferrably one with more RAM?  Did you have the same symptoms?
Message 10 of 11
(5,623 Views)
