Labview MODBUS modules problem
Hello I am trying to use to LabView ModBus VIs to access data from a modbus slave over TCP, but I am having difficulties. The slave I have has an assigned device ID as 1 and I am trying to read register 400001 and the preceeding 36 registers. I am admittedly new to the ModBus protocol and not sure if I entered the parameters correctly for the VI I am using. I was also wondering would it just be easier if I just use TCP write and TCP Read instead of the ModBus VIs?
Any help is appreciated!
(2,966 Views)
No, your parameters are incorrect. The '4' prefix is assigned when you select the Read Holding Registers instance so you just place the start of the addresses (i.e. 1 in your case) and then the number of addresses to read.
(2,961 Views)
Ok Thanks I see my error there after re-reading the documentation on ModBus. Now I am still having trouble with the VI though. It keeps returning error code 56 when I try to run the VI. It's beginning to make me think I may have issue elsewhere. I have been using a ModBus utility (Simply ModBus) and it's returning sensible data when I try reading the register, but I can't get it to work in LabView.
I have assigned the slave with a slave ID of 1 so I opened the MB Ethernet Master Query VI and changed the Unit ID to 1 in MBAP Header. I believe this is correct, but I want to double check.
(2,950 Views)
