Labview : Modify the value of an indicator during a run
Good morning,
In order to complete a project, I have to find out how to modify the value of an indicator during the same execution.
My indicators depend on 2 commands (drop-down lists): temperature and pressure.
So I would like to be able to select in my drop-down lists another T ° or P value, during execution, and that the values of my indicators change.
I thought about putting an event structure but I don't know how? Do you have any ideas ?
Thank you in advance !
(1,777 Views)
Hi Projet,
what have you tried and where are you stuck?
Mind to attach your VI?
(1,772 Views)
Hello, I have the same problem, I made an "event" structure with "value change" for my dropdown list but I don't know what to put in to make the program happen again when I change the dropdown list during the execution.
(1,726 Views)
Hi Student,
When you want to execute a "part of code" more than once then this "part of code" should be inside a loop…
(1,719 Views)
Indicators just display the value that 's in the connected wire.
Seems you have little experience with LabVIEW, so here are some tips:
  • If you want specific tips, attach your code so we can see what you are trying to do. Your current description is insufficient to tell what the problem is.
  • Learn the basic principles of dataflow (i.e. if the indicator terminal is after the loop, it will not update until the loop has completed. If a control terminal is before the loop, it will not get read again once the loop has started, etc.)).
  • Learn basic program architecture (toplevel loop, state machine, etc.).
  • Forget about event structures until you are more familiar with general LabVIEW programming. They are not needed for this problem.
(1,712 Views)
