Labview Motion .flx files not there
My program that I wrote on Labview worked yesterday fine, however today when I run it, the function can't seem to locate half ot the movement control files. Even the example code in Labview doesn't seem to function and functions such as reset motor and such is not being found by Labview when loading the vi. I am not quite sure what is the problem
(3,203 Views)
Khk4085,
Did you download a new version of LabVIEW? What changed between when the program worked to when it didn’t work? Do the VIs in question have a grey box and white question mark for an icon?
This seems like a driver association issue. I would recommend running a Repair on you NI Motion driver or updating your driver if you installed a new version of LabVIEW and have yet to install the drivers over the new LabVIEW platform.
In the future, you should consider posting motion questions in the Motion Control forums. It will help propagate a better community response.
Blake C.
www.ni.com/support
(3,159 Views)
