Labview NOT working with Raspberry pi3 B
Dears
 Please help in this issue of raspberry pi3B which after installation the labview 2014 32bit on windows 7 and following all the instructions of makerhub for setting up the SD card and other details I have now two issues before attempting the advanced blinking VI:
1- first issue the LED continue to be ON all the time after installing the labview into the SD card as shown in picture Capture.PNGCapture.PNGIMG_0939.JPGIMG_0939.JPG
this case happens even before uploading the VI to the RPI3 with last operating system (
RASPBIAN STRETCH WITH DESKTOP
Image with desktop based on Debian Stretch
Version:April 2018
Release date:2018-04-18
Kernel version:4.14)
and for this case when i changed the pin from no.7 to pin no8 I got the message below
Untitled.pngUntitled.pngand I have asked about this issue n Raspberry pi .org forums and someone answer me to use the  http://downloads.raspberrypi.org/raspbi ... 017-07-05/
2-and a second case happens after installing the raspbian 05-07-2017 which is the LED was NOT blinking and always OFF even I checked the voltage across it was 1.6 volt DC.
same thing when i installed the NOOBS I got NO blinking and the LED always OFF.
and finally today i have follow the instructions in the link below and still no changed in two case which I have
file:///C:/Users/iqmudha/Downloads/Install%20Guide%20for%20RPi+LabVIEW+MakerHub.pdf
is there any help for this case since I'm lost for two weeks without any help from Makerhub team.
(4,844 Views)
You might get better support on the LabVIEW MakerHub and their  LINX forum
=== Engineer Ambiguously ===
(4,818 Views)
Hi
 I ask there but since Sat May 12, 2018 12:07 pm no one answer me
please lets keep it may someone can help
thank you
(4,812 Views)
Accepted by topic author Mustafasei
The pinout isn't straightforward for the PI3.  Google PI3 pinout and download one of the pictures they have of the pinout to make sure you have it connected correctly.
Bill
CLD
(Mid-Level minion.)
(4,803 Views)
Hi
 I used this pinout of RPI3B
https://www.jameco.com/Jameco/workshop/circuitnotes/raspberry-pi-circuit-note.html
output in VI was no.7 must be pin no.26
please advise if I'm wrong
(4,793 Views)
