Labview NXG UI issue
I would like to report an issue we are facing.
If we open a sub vi's front panel , the first time it opens the UI/Front panel looks perfect with a titlebar. But if we close the front panel and if we open/call the subvi's front panel again , the title bar is not visible the 2nd time and we are not able to close the window also.
(We have taken care that we close the window programmatically using built in window close functions and also closing the window references properly)
I have attached a small clip for better understanding
We are using version 3.1.1
(2,783 Views)
Hello Tinku130490,
Thanks for sharing this unexpected behavior. I remember seeing something similar in 3.1.1 when opening and closing a VI window multiple times would not show properly; and I filed CAR #739531.
I recommend you try your project with version 4.0 of the software and see if the problem persists with the update. Moreover, you can open a service request with our support team and share your project with us so we can investigate if it's the same behavior of the mentioned CAR.
All the best,
(2,443 Views)
