Labview PDA error: g_array_7 is a missing VI or C File
What is this?  It has compiled everytime I have worked on this for the past 2 months, then all of a sudden, I get this error message, but it isn't specific enough for me to even guess what is wrong.  The entire message is:
g_array_7 is a missing VI or C file
function is missing or C file
(2,951 Views)
What do the names "g_array_7" and "function" mean to you? Are these names of VIs, DLLs, function calls within a DLL, etc.? I know that one cause of this error can be forgetting to include the source code for external DLLs that are called by a VI. Make sure that's not the issue you are experiencing and try to clarify for us what those names in the error correspond to in your application. To my knowledge, those name do not refer to any VIs or functions native to LabVIEW. Also, try building one of the example VIs that ships with LabVIEW to ensure that this is indeed a VI-specific problem.
Kind Regards,
E. Sulzer
(2,942 Views)
Well, those don't mean anything to me.  I did finally get it to work, but I'm not sure how.  I remember seeing some errors like that before when I had a tab control on top of a tab control on the PDA control panel.  I started to move some controls around that were out of the viewing window and then it compiled.  It seems kind of strange.
(2,940 Views)
