Labview Python Node return list error
Hi all,
Below I tried to return a list from Python Node into LabView2018 with following Python code:
def return_list():
return [1,2,3]
But it returned error. How to solve this problem? Many thanks!
(3,984 Views)
Hello
I run your code and worked good.
I used python 32 bits and do not forget to install numpy  (pip install numpy from command line)
(3,894 Views)
(3,891 Views)
interesting, I can run this with LabView 64 Bit, Python 3.7x 64 bit (C:\Program Files\Python37)
(3,875 Views)
Thank you guys. I have installed numpy so It is still a strange error to me. One workaround for me is to return a string and extract data from it. By the way, I am using embeded python.
(3,838 Views)
