Labview RT 8.6 connection issues
Hey everyone,
  I am trying to run a pair of computers using Labview RT (a PXI chassis running Labview 8.6 RT controlled by a Dell machine running windows 7) and so far have been unable to obtain full connectivity.  I can manipulate the target machine with the Windows machine via MAX (I can reboot it remotely, etc.), but when I open a project on the Windows machine and try to connect to the RT target, I get the 'Conflict Resolution' dialog window with the following messages: 'Unable to resolve from current dialog' and 'Failed to connect to Real-time target'.  The machines are connected via ethernet port.  The Windows 7 machine has the latest Labview RT module installed, and the PXI machine has been used as a RT device by other PXI machines.  What steps should I take to resolve this?
Many thanks
(3,028 Views)
Hi bjw5,
Are you connected via a crossover cable?  Please see the following link:
http://digital.ni.com/public.nsf/allkb/72AE8CADA1AF075686256A16005D55B1
Regards
Che T.
(3,011 Views)
