Labview RT and Notifier uSec timeout
Is Labview RT going to support a uSec timeout feature for the Notifiers?
(3,485 Views)
Do you want a feature then suggest it here
(3,470 Views)
Currently, the timeouts for notifiers are specified in milliseconds.
I would suggest refering to the link that is posted above if this is a feature that you think should be added. Otherwise, the release notes for the next version of LabVIEW RT will include this if it is a new feature.
Logan H
(3,457 Views)
I have not dug into the low levels of OSs and hardware lately but I suspect that technological limits will or are playing a part in this. I would not suprised if uSec timeout would actually consume most of a CPU just servicing the clock interupts (based on one instruction per clock cylce which I question adn 1000 instruction per interupt).
So this leads me to ask
"What cahllenge are you facing that makes a 1 uSec timeout something useful?"
Ben
(3,452 Views)
