Labview Reference Manual
Hi!
I'm looking for advanced reference manual, about LV09. I would like to be more familiar with the following:
 - What makes the VI front panel to load
 - VIs and loading to Memory
 - VI and Application Properties and so on
Is there any official manual for LV09 for my questions?
+++ In God we believe, in Trance we Trust +++
[Hungary]
(3,511 Views)
ummm... the LabVIEW Help?
(3,504 Views)
There is a Function and VI Reference Manual, but my version is 1998...
Is there any newer version?
[Hungary]
(3,500 Views)
Did you click on the link in my response?
(3,492 Views)
Anyway, I'm looking for a solution for hiding Startup VI in my App. The only usable solution that I can use is: Set Startup vi transparently 100% and after my bootup vi finishes, set the transparently to false. It works most of the cases, but sometimes my FP appears inspite of set it full transparent.
My another problem is, how to reduce the application boot time? I mean, when I start my LV.exe, it loads for a 5-6 sec and then my program starts... Is there any way to reduce this time?
[Hungary]
(3,490 Views)
Of course...
[Hungary]
(3,487 Views)
You Know, Mark Ridgley and I used to share a cube wall (or two) This might help.
Splash Screen
Even MS office products use a splash---- so does LabVIEW.  The time it takes to load an app is ---well, the time it takes for the OS to load an app.
(3,480 Views)
