Labview Remote Panel and Client Aspect Ratio
Dear all professionals,
I had create an application with remote panel (webserver) enabled. I found that there is relationship between aspect ratio of client device display and the remote panel screen size. Here i attached two images of remote panel in browser which both remote panel are opened using different aspect ratio of client device.
The left 1 is the device with 1.5 aspect ratio while the right 1 is the device with 1.78 aspect ratio.
As you can seen from the images, both remote panel are shown in different size. May i ask do i miss something in the remote panel configuration?
(3,417 Views)
I have the same behavior, you need to play with the zoom of your browser if you want to see the same area of the user interface.  This being said, it is not a permanent solution, since the client can change the zoom %.
Michel
(3,404 Views)
Hi Michel,
Thank you for your reply. I also notice that the zoom % of browser is one of the issue that caused this behaviour. In the same aspect ratio with server computer( where the application running), changing zoom to 100% will help to fit remote panel that I already set when I developing the remote panel vi. But if for different aspect ratio, no matter how u change the zoom % , it won't fit the frame. I just wondering whether got another solution for this issue or not 😞
(3,398 Views)
No solution on my side.
(3,393 Views)
