Labview Siglent 2042X Data Capture
I am trying to get frequency counter data out of my Siglent 2042X waveform generator using NI LabView 2023 Q1 (32 bit) hobbyist edition.  I am running windows 10.  I am new to LabView.  I have researched the knowledge base and tutorials but have not found a solution to the error that I am getting.
So far, I have set up the instrument with a USB connection and with NI MAX I am able to read and write "*IDN?/n" to the instrument without errors.  See screen shot below.
I set up a basic open, write, read, close program that develops a time-out error at the read block. See below.
Any ideas of what I might do to fix the issue?
Wes Winkler
(2,497 Views)
Did you use the correct configuration (baud rate, termination character etc)?
Anyway, there is a library and example available at IDnet (Siglent Technologies SDG2042X Function Arbitrary Waveform Ge - Instrument Driver)
Download and extract the library to <LabVIEW>\instr.lib
Open and explore the example.
https://tmesystems.net/
(2,476 Views)
You need add a VISA property node to ‘Enable Termination character’ and also need to set the termination character to the numeric equivalent to \n.
https://www.ni.com/en/support/documentation/supplemental/06/termination-characters-in-ni-visa.html
Currently what is happening is the VISA read is just waiting for 1024 characters and it isn’t getting them all and timing out.
(2,389 Views)
Also you need to check the string for  ‘idn?\n’ has got ‘\ codes display’ enabled.
https://www.ni.com/docs/en-US/bundle/labview/page/backslash-codes-display.html
otherwise you are not sending what you think you are sending and the instrument doesn’t understand
(2,386 Views)
That did it!  thanks for the tip.  I enabled the codes display and found that there were two backslashes.  I removed the extra backslash and the program worked.
(2,354 Views)
Ahhhh! So you were sending a littoral "*IDN?\n" 7 characters rather than a "*IDN?" followed by the newline character 6 characters as shown in the test panel ("\\" is the escape code for a single Backslash character while "\n" is newline)
(2,336 Views)
