Labview Starter kit 1.0 getting disconnected after some time.
I am using Labview Starter Kit 1.0 ,Labview 2010. When i open the Measurement ans Automation Explorer, i find that the starter kit is getting connected initially,but within a couple of minutes it is getting disconnected on its own. I haven't had this kind of problem before(hav been using it from 6 months succesfully).
It is not getting connected even with NI Hardware setup.
Has anybody had this kind of a problem before.Can anybody suggest what to do.I have tried 3 dif lan cables,so cable is not the problem.
Harsha.
(2,484 Views)
I did have similar problems and I figured all that I installed too many real-time components.  It might not be the case with yours but you might try.
(2,458 Views)
I'll try it out..
(2,450 Views)
