Labview TI DSP CCS variable change
Hello all,
I am working with a TI DSP TMS320F2808PZA that is controlling a buck converter, and I am attempting to make a Labview VI that can be used to change variables ( such as "output voltage", and conditional variables) within the Code Composer Studio codes. I have seen that NI makes a "Labview DSP Test Toolkit for TI DSPs," but I do not think that I can use that for this purpose.
I have limited Labview experience, so tutorials and example files would be helpful if available. Please help! I've done so so much Googling 😞
(3,943 Views)
Hi Mumiekage,
Here are some great resources for learning LabVIEW, as well as getting you started with your application:
Various resources for learning LabVIEW :
https://learn.ni.com/learn/article/labview-tutorial
LabVIEW in 8 minutes on YouTube :
http://www.youtube.com/watch?v=wKWaTbiaDb8&feature=related
Now, in terms of interfacing with Code Composer Studio, here are some links to the TI DSP Test Integration Toolkit:
NI LabVIEW DSP Test Integration Toolkit:
http://zone.ni.com/devzone/cda/tut/p/id/5839
Connecting to TI DSPs Using the LabVIEW DSP Test Integration Toolkit
http://zone.ni.com/devzone/cda/tut/p/id/3151
LabVIEW DSP Test Integration Tookit User's Manual
https://www.ni.com/docs/en-US/bundle/323452b/resource/323452b.pdf
Note that this toolkit has not been supported for some time, but it should let you do what you are looking for.  When you install the toolkit, there are examples at [LabVIEW]\examples\DSPTest where [LabVIEW] is typically C:\Program Files\National Instruments.
(3,923 Views)
