Labview TPC with Third part Touch panel Computer
hi,
            I have labview TPC module, i created executable file for windows CE 5.0  and build it. aftter i copy the exe file on the thirdparty Touch panel PC.
is it required to copy any other supporting file to run my application?,...
if you have any manuals send me.
Balaji DP
(3,146 Views)
I believe you don't require any other files unless you are using DAQmx Base, Shared Variables, NI TPC Service etc. in your application. Otherwise, it should work fine. Have a look at the following manual:
Getting Started with the LabVIEW Touch Panel Module
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,122 Views)
