Labview Touchpanel project + Windows CE + Beckhoff
Hi
Im using labview mobile module to create a HMI, that will  be running in a Windows CE OS device, from Beckhoff Automation (C6915-0000).
Here is the deal: I need to use a dll (TcAdsDll.dll) and dont know how to make it work on the mobile panel project I created. In a non mobile there is no secret at all, you just call the library node and it works fine but when using mobile I read there is necessary to create a "stub library" or something like that to call the dll but I did not found how to do it.
One more thing: I dont know where to find the TcAdsdll.dll functions prototypes with all arguments and returns. They are necessary to build my application in Windows CE right?
Attached the projected I worked on from yesterday to today. Just cant build
thanks a lot
Fernando
Bachelor in computational physics, IFSC, USP
Equitron Automation
(3,417 Views)
Hi Fernando,
In the following link have an example of wrapper DLL.
http://digital.ni.com/public.nsf/allkb/D1705141137852B586256A63007490A7?OpenDocument
You need the function prototype to know the what data you need enter in your function and datatype.
Abel Souza
Applications Engineering
NI Brazil
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(3,392 Views)
