Labview VI stops working after one launch
I am developing a labview program for using with my microcontroller for two stepper motors.
So far I just have a testing app, which would just connect to one of my steppers and move it to left. The problem is that after one run of a program, every other time I push Run(play button) everything stops immediatly after I do that and nothing happens. It only starts to work after I restart my computer. Does anyone maybe have any ideas about the problem?
(3,358 Views)
Hi mazhius,
I guess the problem is within YOUR VI - but you didn't attach it…
(3,345 Views)
Are you closing the connection?  Sounds a bit like the connection to the stepper is locked, but as mentioned, need a bit more to give better information.
Jon D
Certified LabVIEW Developer.
(3,306 Views)
What is the mechanical action of your stop button? (Make sure it is set to latch action).
(3,288 Views)
